Results 1 to 3 of 3
Thread: New from Hartley
    Santa Cruz, CA
    696
    Default New from Hartley
    Anybody think this would be good in a seven?
    http://www.h1v8.com/H2.html
    What tranny would you use?
    All of the hayabusa sevens I have seen have the engine leaned over to the left...not a problem on a RHD car, but for us here in the USA it puts the weight all on one side as well as interfering with the pedal box. I wonder if this kit could help move the engine to a more traditional location?
    Tom "ELV15" Jones
    http://PIErats.com
    Would be very good in a Seven, IMHO. Regarding the gearbox, the "Pricing" page had the following listed as one of the options:
    "Special small diameter bellhousing to mate the H2 to a Ford Sierra type 9 gearbox. The small diameter allows the engine and gearbox to be lowered significantly as the lowest part is about 116mm from the crank centerline... $625"
    Regarding the offset to the left in a typical Hayabusa installation, it appears that would not apply here, because the Suzuki gearbox is not used here. There is a pdf drawing on the "H2 Specs" page that depicts the flywheel at the end of the crankshaft.
    Wild.
    Santa Cruz, CA
    696
    Sean,
    It's cool that it can bolt up to a std transmission, however I thought one of the nice things about using a bike engine is that they come with a sequential transmission.
    I also wonder about the weight difference with this hartley kit + t9 transmission vs a std engine + t9.
    Tom "ELV15" Jones
    http://PIErats.com
