Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: WTB Seats
    May 2013
    Pleasanton, CA
    61
    Default WTB Seats
    Hello group,
    Looking to buy any extra seats from those of you who may have upgraded. The seats in mine are plywood and carpet pad, so I'm not too picky. Anything would be better.
    Thanks
    Aug 2009
    Atascadero and Pacific Grove
    42
    I just ordered new seats for my Birkin , if I like them as much as they cost, I will be selling my stock seats in a couple weeks, they are in very good shape and black
    I have a single seat of this model (with neck rest).
    http://www.caterhamparts.co.uk/produ...d_product=4561
    Runners included. The only thing that I need to check is if this seat is specific for the SV model I have, or if it is generic across all Caterhams. Does anyone know about this?
    May 2013
    Pleasanton, CA
    61
    Quote Originally Posted by DaveL View Post
    I'd like to get a look at the Birken seats, if and when. Definitely two needed. Easy drive for me to get there.
    May 2013
    Pleasanton, CA
    61
    Quote Originally Posted by CASwede View Post
    ..ahem. Yes, Birkin. Not Birken.
    Aug 2009
    42
    I am planning on driving in the British car owners Auto X Sat June 22 at the cow palace , in Daly city. I could throw my Birkin, seats with tracks and brackets in the back of my truck ( I tow my 7 to most events ) if you could bring your 7 you would see how much fun Auto X is and helpful other 7 owners are ( you can just watch if you want ) and/or I will let you ride shotgun with me, DaveL
    May 2013
    Pleasanton, CA
    61
    That would be great! Very interested in Auto X, and that day I have free. I'd probably bring my truck. My 7's front end setup is not good, so I'll be tinkering with it next weekend. I'll PM you later with contact info and such.
    Magnus
    I am interested in your seat if it fits standard size car.
    I'll bring it to the dyno day.
    San Diego
    973
    If you are able to post on blatchat, I suggest that you tell them about your 7s specs and what the handling problem is. You will get plenty of responses and recommendations on where to acquire the parts needed to fix your handling.
    Two cents from me: Stiffer springs up front and adjustable shocks at both ends.
    Do a BlatChat search on spring rates. Lots of info to be found (some to be taken w/ grains of salt). You don't have to be a member to search & read.
    May 2013
    Pleasanton, CA
    61
    Blatchat has been extremely informative. My issue is about 5 degrees of negative camber, and major toe out. Blatchat had a great tip using bolt and nut to crack open the ball joint. Flat flooring is another project I have on tap.
    The bolt and nut method is mine! I gave it to them freely years ago.
    http://californiacaterhamclub.com/ch...ght=Ball+joint
    May 2013
    Pleasanton, CA
    61
    They'll see you in court.
    The club has scales you are welcome to use for the flat flooring. They are currently in So. Cal. but show up in N. Cal. from time to time.
    We have other alignment tools as well.
    And yes Blatchat was extemely helpful when I built my car. These cars have been sold as a 'kit' ,as in put it together yourself, since 1957. However, the build manual is not yet finished. It works for most things but then you come to a point where it says absolutely nothing. Generally you can find the answer on Blatchat.
    I may have access (through Motivo Engineering) to a flat table. If they are OK with it, we could do a weekend in their shop corner weighting our cars and setting up their suspension. I also have a good local source for the M14 1.5mm pitch nylocs that we will need to replace if we do camber adjustments.
    We shall call it Suspension Day.
    I want to build a Seven Specific version of one of these to go along with the scales.
    Just need time and money. Time is the problem.
    I figure I can come up with something made in aluminum for ~$500. Adjustment will be limited but it will fit Sevens and F2000. It would be built around our scales.
    Attached Images Attached Images
    May 2013
    Pleasanton, CA
    61
    Relief! $18 at Costco for a cooling-gel cushion, and this little number fits perfectly into the bucket of the bench seat. I could drive it all day now.
    Man, I must be getting old.
    I'm still looking for seats if you find some around, but my tailbone is no longer in a hurry.
    Aug 2009
    360
    Interested?
    EscondidoRon
    '62 Lotus Seven
    '84 Turbo Esprit (x2)
    '14 Evora
    '77 Esprit S1 (RIP) :(
    "A man must keep a little back shop where he can be himself without reserve. In solitude alone can he know true freedom." -Michel De Montaigne 1588
  20. #20
    Apr 2013
    44
    Default your seat
    Quote Originally Posted by escondidoron View Post
    Interested?
    Hello there,
    would these seats fit a caterham classic se 1998 with standard size chassis, same for the tunnel cover.
    Best,
    N6
  1. WTB new seats for Birkin or Caterham
    By Mike Bearden in forum For Sale/Wanted
    Last Post: October 18th, 2011, 07:57 PM
  2. Tillett Seats too narrow. >sigh<
    By magnusfeuer in forum Questions and Answers
    Last Post: January 16th, 2011, 09:45 PM
  3. Tillet seats and crotch straps.
    Last Post: September 3rd, 2010, 09:58 PM
  4. Seats for the Birkin
    By scottspiess in forum Questions and Answers
    Last Post: August 15th, 2007, 04:12 PM
  5. Tires and Seats for a Seven
    By RogerL in forum Questions and Answers
    Last Post: August 28th, 2006, 08:21 PM
