Results 1 to 18 of 18
Thread: How to cut out a hole in the bonnet?
    Mar 2010
    Texas
    44
    Question How to cut out a hole in the bonnet?
    Hi guys. Finally got my ITB's in and with the sausage filter on I need to make a hole in the bonnet. Being an SV it doesn't have to be accurate and surround the filter, its more to put a mesh grill in for clearer air flow. The filter does protrude a few mm's at the front but it will compress in a little with the hood on.
    What is the correct tool/method to cut a painted bonnet? Any tips appreciated.
    Adam
    Attached Images Attached Images
    2010 Roadsport SV 170
    I don't have much advice for the cutting other than "take the air nibbler and go for it". But I would recommend finding a way of allowing outside cool air to the intake (and shutting off from the engine compartment). That is probably the cheapest way of gaining a few horsies. If the common rule of thumb is right, a 50 degree lower temperature taken from outside is worth about 10% gain of power. It could make your car an SV187 ;-) Well, assuming the ECU knows about it.
    Mar 2010
    Texas
    44
    Power wise already a little past that, I had to get an unlocked ECU to tune with the mods I made. It was closer to the R400 spec than R300. Now hopefully somewhere between a R400 and R500..
    I want to start with the simple approach rather than fabricate an airbox etc. Getting the hole cut cleanly is the next big task!
    2,245
    Where do you live?
    Send me a PM and I will tell you how I enlarged mine and folded over a bead around the cutout, the bead makes it more rigid around the cutout but I don't think the paint will do well. Mine is unpainted. If you don't want the bead some use a strip of rubber edging around the hole. I don't know where to get the edging material. Maybe Caterham?
    If you are going to use the bead, just get a nibbler as Gert says, make a layout and start cutting. Practice first on some of the area that is being removed to see how it cuts.
    Quote Originally Posted by Doug Liedblad View Post
    ........I don't know where to get the edging material. Maybe Caterham?.......
    Autozone/PepBoys/Napa have self-adhesive door edging. You heat it with a hot air gun which makes it pliable and melts the hot glue inside the groove. I used it around the edges of my aluminum dashboard.
    McMaster has a dazzling veriety of rubber and plastic edging but you need to glue that down.
    Jan 2004
    Sunnyvale CA
    134
    I have a nibbler that I bought to do this job and I can loan it to any 7 builder
    Rod Swanson
    2,245
    Harbor Freight sells air nibblers for under $30 they work just fine on thin gauge aluminum
    I highly recommend the air nibbler and if you practice cutting to your layout lines it should come out OK.
    Layout a hole or two smaller than you need and practice a time or three and it will come out OK.
    Mar 2010
    Texas
    44
    Thanks, thats the plan.
    Harbor Freight sells air nibblers for under $30 .....
    Put a drop of oil on the nibbler cutter every couple of minutes. The aluminum tends to gum it up to the point it may get stuck.
    Mine's covered w/ something similar to this. Disguises any little, um, variances in the edge.
    2,245
    Gert is correct, the oil will help.
    Mar 2010
    Texas
    44
    The hole came out great, we used a air saw. cut was clean but the trim made it look better still:
    Oct 2011
    23
    Nicely done! Looks great.
    Mar 2010
    Texas
    44
    Quote Originally Posted by centerfireman View Post
    Thanks. Now the decision on making a matching hole on the exhaust side....
    Feb 2013
    17
    nice job!!
    two questions:
    first, how did you mount the mesh to the inside of the bonnet?
    second, did you consider adding an aluminum scoop to the hole? that's what i'm thinking . . . has anyone done this? if so, any advice on making the scoop and attaching it? rivets? do any of the after-market sources make a scoop?
    thanks!
    alan
    Mar 2010
    Texas
    44
    Quote Originally Posted by werthie View Post
    nice job!!
    two questions:
    thanks!
    alan
    I would do a scoop if I was also going to repaint, at this time I didn't want to do that so sticking with the exposed grill for now.
    The grille mesh was found on ebay - look for seller metrorestyling, search for bonnet grille. Since I didn't trust myself on cutting the hole I left it with a friend at his shop, they sourced the trim material and I will also ask what they used to stick it up there (looks like the mastic stuff builders use to stick mirrors to interior walls).
    Aug 2009
    360
    alan
    Like the scoop Lotus fitted to the original Seven S2 when fitted with the dual Weber Cosworth 1340 engine back in 1962?
    EscondidoRon
    '62 Lotus Seven
    '84 Turbo Esprit (x2)
    '14 Evora
    '77 Esprit S1 (RIP) :(
    "A man must keep a little back shop where he can be himself without reserve. In solitude alone can he know true freedom." -Michel De Montaigne 1588
    Mar 2010
    Texas
    44
    The trim was vacuum tubing cut to make it grip on, the goop is 2 part steel putty. Like the scoop above!
  1. SV Bonnet wanted
    By magnusfeuer in forum For Sale/Wanted
    Last Post: July 27th, 2007, 02:21 PM
