Results 1 to 9 of 9
Thread: SuperCarSunday October 6th?
    Default SuperCarSunday October 6th?
    Anyone interested for this weekend?
    I believe the feature marque is Shelby Cars.
    Quote Originally Posted by Doug Liedblad View Post
    Y'all can walk around and look at all the cars that your car can spank the hell out of on track. They're really quite slooow!
    I am back from Germany. And I got my ECU back from the UK after upgrade. Also installed the new Hall-effect TPS. Good news I can start the engine and it idles. Bad news the car does not drive at all. Maps are screwed up and the Baro sensor needs configuration. Maybe I need to calibrate the crank position sensor, too.
    Anyway, it is anyway a moot point. Got to help my son move to Santa Barbara for his new job. Yes, another police job....
    Can't you load your old map?
    Slight hijack...
    Quote Originally Posted by slomove View Post
    What idle voltage did you calibrate it to? Baseline on mine is .25V
    Yes I can and I did. But in my infinite wisdom I had the old TPS de-linearized with a parallel resistor to get better resolution at low throttle. I can not do that with the solid state TPS and thus the mid-range map positions are all shifted.
    The theoretical good news is the upgraded ECU has a self-mapping/learning feature based on the wideband sensor input. I hope that really works.
    The Emerald has an autocal feature. Once that is activated you apply full throttle (motor not running) and release. The ECU then spans the maps over the measured throttle range. Right now it shows 0.46V - 4.37V for the full opening range with 1000rpm idle sitting at approx 0.51V. The whole range can of course be moved a little by mechanically turning the sensor and I tried to get somewhat equal margins to 0V and 5V.
    Sep 2008
    PNW
    274
    I'll be happy to send you a copy of my map, if you think it might help.
    Randall
    Thanks Randall, that might help for comparison. Maybe I can just copy the injection segment into the map file, adjust the microsecond/bit value and try if that give me a better initial map. email is my forum name AT earthlink.net.
  1. SuperCarSunday Sept 1st
    By Doug Liedblad in forum Events
    Last Post: August 30th, 2013, 05:15 PM
  2. SuperCarSunday
    Last Post: July 6th, 2013, 10:06 PM
  3. SuperCarSunday Feb 3rd.
    Last Post: February 3rd, 2013, 06:36 PM
  4. SuperCarSunday October 28th
    Last Post: October 29th, 2012, 06:28 AM
  5. SuperCarSunday 12-11
    Last Post: December 21st, 2011, 01:05 PM
