Results 1 to 5 of 5
Thread: Need advice on P0444 code - evap emissions purge control circuit open
    Nov 2011
    Mountain View, CA
    43
    Default Need advice on P0444 code - evap emissions purge control circuit open
    In further evidence of the rise of the machines, my Seven (237hp Duratec) is throwing off the P0444 code and the MIL is lit. This has happened once before, right after I refueled, making me wonder if it was excess fumes or incorrectly seated gas tank cap causing the error. That first time the fault seemed to cure itself, but this time around it's been persistent for a couple of weeks.
    Car runs roughly, especially at idle, and feels down on power but that might be an illusion; otherwise starts and drives normally.
    Anyone grappled with this issue / have any ideas on find and fix approach?
    Jeremy
    2016 Seven 480 SV in Ballistic Orange
    This is a stock engine? Running the stock ECU?
    Nov 2011
    Mountain View, CA
    43
    Hi Doug, yes completely stock, no ECU mods (yet). I'm chasing the emissions canister vacuum pipes for kinks or breaks, so far no smoking gun. Next up is probably multimeter on the purge valve. Anything I'm missing that's an obvious early check? Thanks!
    Quote Originally Posted by Doug Liedblad View Post
    The Caterham's setup for the Zetec came with a OBDII port. I had multiple codes for all the sensors that were't there. I am fairly sure the canister code as well the fuel tank vent code were reported by the ECU.
    Ultimately I just ignored them as trying to make them go away was pointless. In California, the Specially Constructed Vehicle registration makes us exempt from passing any emissions test.
    Get an OBDII code reader that connects to a smart phone and clear the code.
    Nov 2011
    Mountain View, CA
    43
    Thanks Doug. My code reader can do that.
  1. Circuit of the Americas Track Weekend - Feb 26-28 2016
    By Michael Murphy in forum Events
    Last Post: November 7th, 2015, 08:58 PM
  2. CCC Lap Record: Thunderhill Five Mile Circuit
    By Michael Murphy in forum Idle talk
    Last Post: September 4th, 2014, 06:58 AM
  3. LUCAS 6DA Wiper Control Unit
    By werthie in forum For Sale/Wanted
    Last Post: January 6th, 2014, 12:41 PM
  4. Replies: 1
    Last Post: June 4th, 2012, 07:36 PM
  5. Car Control
    By venom7 in forum Idle talk
    Last Post: February 8th, 2006, 08:34 AM
