Results 1 to 18 of 18
Thread: Car almost back together.
    Default Car almost back together.
    During the weekend I started to setup my new 2-car garage into a first version of an acceptable shop. I still have to paint the floor, find a permanent workbench / storage solution and put up drywalls to get a better light reflection, but I am amazed over the amount of space I have access to.
    As soon as I had my old benches stringed up (se photo), and installed more lights, I got that good old itch that I haven't had in a looong time. 10 minutes later the Caterham was in the position i like most of all, ass in the air, and I got down to satisfy my urges.
    I've now ground down the part of the rear calipers that were rubbing against the Watts linkage, touched up the linkage paint, fixed an exposed electrical wire, removed all the contact cement after removing the carpet on the inside of the trunk (which was trapping moisture and created rust bubbles), f*cked up the alread f*cked up rear paint job, and reattached the rear fenders (with nylon bolts where there is direct alu contact). I had to break just when I was to rivet the gas cap assembly back in place.
    Since I now live exactly 7.6 miles from Cosworth's U.S. headquarters, I am also eyeing my Duratec engine with renewed interest...
    Attached Images Attached Images
    Oooh, I am envious....so much space!
    I think I need to build that garage addition.
    Swing by and have a look if you want to motivate the expense yourself.
    May 2004
    Victorville, CA
    611
    What are you using the black double-pocket bungee device for? Looks like it's holding your jack handle erect ;)
    San Diego
    973
    Is Torrance really 7.6 miles from Manhattan Beach? I suspect that you will find Cosworth is closer than you think, although not cheaper.
    Yes. I think you'll find everything is better north of the curtain. Real restaurants, real shopping (yes, even beyond Bed, Bath & Beyond), real culture etc. And real garages:D
    Jan 2004
    213
    I never thought I'd hear (or read) someone saying how L.A. is more "real" than somwhere else! :o
    - Sean
    Hmm.
    The brakes are crap. It feels like I have new pads that haven't settled in yet. Maybe one or more calipers are stuck. Time to dissasemble.
    2,245
    Magnus
    If I recall from my visit just before your move the rotors were a bit rusty.
    It might be all it needs is bleeding and run them for awhile.
    There was a discussion about "mushy" brake feeling even after thorough bleeding on the Birkinowner forum. This was related to non-parallel misalignment of caliper/pads/disk to be cured by
    - long driving until worn even
    - sticky sand paper pads on the disc (and a respirator)
    - some shims if it is totally off
    Additional info.
    Replaced DOT 4 with DOT 5 about 18 months ago. Did thorough flushing of the system (0.4 litres or something like that) to get rid of old fluid.
    Small squeal from rear left when warmed up and not braking, but not pulling in any way.
    I'll dig into this.
    Another question on a similar topic.
    I am thinking of going Mintex 1144 on my front and rear pads (while I am tearing down the brakes). Anyone has an idea about compabillity? I saw on blatchat that a Triumph Spitfire Mk III was used to source the Caterham front calipers.
    Is this true? If not, is there another make/model I can use when shopping?
    Lots of info on Blatchat, like:
    Richard Price
    Anyone got a sock?
    Location: Newcastle, Staffs. Posted - 29 September 2005 16:11
    report this post
    For standard front brakes, the Mintex part Number for 1144's is :- MGB533M1144.
    Don't fit 1144's in the rear with standard brakes, You'll end up with too much bias to the rear.
    With my standard brakes, I'm currently using 1144's in the front, and the caterham blue pads, normally used with uprated fronts, in the rear. I understand, the blue rears have a higher coefficient of friction than the standard pads, but not as high as 1144's - it's a setup that works well.
    Car is up and running thanks to Doug who lended me his brake pads.
    I even polished the whole thing and am currently waiting for the wax to dry. Tomorrow morning, I'll head down to the Qualcomm stadium to see if I can participate in the AutoX event. Expect horrible track times.
    Magnus, so how's it running?
    San Diego
    973
    It ran well enough to win its class in a San Diego autocross today.
    Albeit not with me at the wheel.
    Micah and I shared the car yesterday and he took a wildly plowing Caterham and handed everyone in its class (inlcluding me) their asses. Quite impressive since his only Seven experience up to that point was 10 minutes around the stadium.
    I'll firm up the rear to see if I can get the front to bite a bit more.
    Who's Micah? That's not Sveeedish for 'Mika' - as in Hakkinen - is it?
    Edited to add: I know nothing about auto x. What class did you run in and what kinds of cars are the competition?
  1. Ok, I am back.
    By magnusfeuer in forum Idle talk
    Last Post: January 27th, 2007, 05:31 PM
  2. I'm going to paint a bull's eye on the back
    By venom7 in forum Idle talk
    Last Post: February 14th, 2006, 10:12 PM
  3. A pat on our back is in order.
    Last Post: March 10th, 2005, 09:29 AM
