Results 1 to 5 of 5
Thread: Fuel pump question
    May 2004
    Victorville, CA
    611
    Default Fuel pump question
    I'm replacing my fuel pump and filter this weekend with new units. They are inline, mounted outside the fuel tank. I noticed that the old pump and filter are hooked up so the filter is inline after the pump, but I remember reading somewhere that it is best to put the filter before the pump so that it protects the pump too. Any opinions?
    Thanks,
    Stan
    No real opinions, but considering that so many regular cars (and Caterhams) have their pumps mounted inside the tank, before the filter, I wouldn't worry too much about it.
    You will have an easier job to replace the pump than I did.
    May 2004
    Victorville, CA
    611
    Quote Originally Posted by magnusfeuer
    Yes, it looks like it should be easy (famous last words).
    Woody mounted everything nicely, with the pump and filter clamped to an aluminum plate, which is bolted to the bodywork with rubber isolation grommets. The new pump and filter have the same size tubing inlets/outlets as the old so should be a straight forward swap. I will probably get new hose to be on the safe side.
    Stan
    I got Woody's pump kit with the high pressure filter, too. But when I mounted that I put another cheap in-line fuel filter in a metal can from Autozone into the sucking hose. No specific reason but I was concerned about possible foam degradation and breakdown over time in my fuel cell. Costs you only a buck or two.
    Gert
    Jan 2006
    47
    Even in-tank units have some filteration at the pickup line
  1. Fuel Pump
    By New2 7's in forum Questions and Answers
    Last Post: March 11th, 2007, 04:39 PM
  2. Mapping & Fuel Pressure issue
    By Roll a 7 in forum Questions and Answers
    Last Post: September 26th, 2005, 12:24 PM
  3. Continued woes.
    By magnusfeuer in forum Idle talk
    Last Post: April 6th, 2005, 10:16 PM
  4. Now you too can have an external fuel pump!
    By magnusfeuer in forum For Sale/Wanted
    Last Post: April 5th, 2005, 04:15 PM
  5. Fuel Cell
    By slomove in forum Questions and Answers
    Last Post: April 7th, 2004, 06:37 PM
