Results 1 to 3 of 3
Thread: Widetrack brake lines
    Santa Cruz, CA
    696
    Default Widetrack brake lines
    Can somebody with a widetrack setup let me know how long the front brake lines are?
    ....and if you have std brakes, do they use a banjo fitting, or do they screw directly into the caliper?
    Here is a pic of my current setup
    Attached Images Attached Images
    Tom "ELV15" Jones
    http://PIErats.com
    Brake lines including fittings are about 13" long or so. Distance from body to inside of caliper about 9". Fittings are the same as your photo. You should be ok w/ what you have, based on the photograph. My brake lines are stretched more taut than yours. Note that I have uprated calipers and the fitting on the caliper is horizontal, not vertical.
    Santa Cruz, CA
    696
    Thanks Chris. I think my car has lines from an "uprated brake/widetrack" setup. Looking at the pictures of the replacement lines on the RMSCI and Caterham.co.uk sites, it looks like the "std brake/widetrack" lines have banjo fittings, so I was thinking that my setup might be wrong.
    ...and now I have a widetrack set of wishbones, but need to figure out the brake line situation before I fit them.
    Tom "ELV15" Jones
    http://PIErats.com
  1. brake bulb model# ?
    By Boxologist in forum Questions and Answers
    Last Post: December 14th, 2006, 09:43 PM
  2. 3rd LED brake light
    By Scott E in forum Questions and Answers
    Last Post: August 5th, 2006, 11:30 AM
  3. Rear brake pads
    By Anonymous in forum Questions and Answers
    Last Post: September 8th, 2005, 04:08 PM
  4. Emergency Brake Regulations
    By slomove in forum Questions and Answers
    Last Post: July 16th, 2004, 02:56 PM
  5. Brake and rotor inspection complete
    By Elv15 in forum Questions and Answers
    Last Post: May 22nd, 2004, 03:00 PM
